1 - 1 of 1 Posts
I just Purchased a 69 M Code XR7 this week and it needs a lot of work. Can anyone tell me the pinout on the Drivers Power window? The Lock switch I assume is a Normal Closed switch that provides ground to the window motors. The Left and Right switches should be the same. There are 6 pins on each switch what is the pinout for those pins? Thanks in advance for the info. So stoked to own a Cougar
1 - 1 of 1 Posts
