Hello,
This my first technical related post. I have a 69 XR7 convertible with inop rear windows. They will not work from the rear switches or the master switch panel. Drivers window works fine and the passenger window is a little slow. The master power switch lock out looks to be inop as well.
I have looked at several posts on this site and the relay and possible dirty switch contacts could be the culprit.
Before I take a look at the master switch panel, how do I remove the trim around the switches on the door panel? Is there a tab that is depressed with a screw driver. I love this car and driving with the top down and the rear windows up will look pretty bad. Thanks for the help.
