Jenny and I are starting to plan for re-installing the glass in the Eliminator and we need some advice.
The rear window is no problem. I have the new gasket, the bedding compund, the rear window and have done this type of install before. Although it takes some time and patience, it can be a fun project for an hour or two. (I like to take it slow and after the headliner is in.)
The quarter windows. Hmm ... here's a question, I have two sets. One is bonded in their channels and the other is not. Do I trust 40 year old adhesive and use the old ... or should I remount the loose set into their channels with the 3M Channel bonding adhesive I see at WCCC? The glass is nice in either case.
In regards to the Driver's & Passenger windows ... here are my real questions:
- Do I mount glass into the channels outside of the car or with the channels attached to the regulator?
- What are the offsets for the channel. In other words, how far from the front should the front channel go and how far from the back should the rear channel go?
- The regulators seem to move fine, should I consider replacing any bushings?? I do plan to use lithiam grease on the tracks and guides.
- Should felts go in before or after glass. (I am thinking after.)
- Are there other parts we should consider for replacement?
- When glueing in the glass, the channel is wider than the glass. So is there any "pitch" in regards to angling the glass within the channel?
- Should I wait until all weather strip is installed so the window can be rolled up to max Height and adjusted to fit the door jam prior to letting the adhesive set??
Even though there are a lot of questions, I am kinda looking forward to this step.
But finally, an opinion survey ... although our glass is SUNX, what would ya'll think about a darker tint? As this is an Comp Orange Eliminator ... I kinda like the thought of having darkened windows on it. I dont see this alot on other peoples cars ... but I thought I'd toss that out there. (PS - I did see Don's blacked out windows and that is what really got me to thinking about this. They look really cool.)
