I have considered the same thing. I am actually looking to install an LT1, LS1, 5.0L EFI, or 4.6L SOHC PI motor into my cougar. It's whatever donor car I find first.I had my 69 vert on Ebay a couple weeks ago and it petered out at $16k. My great idea is to drop a used LT1 motor, trans, a/c etc in it and keep it. Am I crazy? I think it would be bad ass
275HP/330tq stock vs a PI 4.6L 260hp/300tq.That actually made me a bit nauseas when I read this. With mustang, mod-motor powertrain readily available, why even consider a bowtie?
I've only seen one stock LT1 make 275 rwh and that was my buddy's '96 WS6 that made 286...all the rest were between 252 and 259 and change. GM has overrated their ponies for a long time. I'm not saying the LT1 is a bad engine, but the fastest way to kill the unmistakeable sound of a muscle Ford, is to grop another manufacturer's engine between the fenders. I say; if one likes the LT1 and LS1 engines (both are swell), then find a late '60's Poncho to build. There's alot of fellas that would love a '69 Coug' to restomod with Ford muscle.275HP/330tq stock vs a PI 4.6L 260hp/300tq.
Now, that 275 is conservative and it's based on a single exhaust pipe and restrictive intake tube. When you go dual exhaust and free flowing CAI, you start seeing 315HP/340tq. Not to mention how well they respond to bolt ons. LE2 heads, good cam, and a TB, you are talking 400RWP, no modular can come close to that without FI. Of course the LT1 isn't without fault, it has an ass backward cooling system and that horrible optispark.
I had a 93 formula fireturd before my cougar and it would absolutely dust my sisters 99 GT.
Sounds like you could decrease the value of the car and the engine at the same time.My great idea is to drop a used LT1 motor, trans, a/c etc in it and keep it
We can talk all day long about LT1s spanking 5.0s and 4.6s, and vice versa, but the fact is; I used to ride around in an '85 Buick Century T-Type (non-turbo 3.8) that spanked them all...some cars are freaks.
If you get a 94-98 block and slap 99+ heads on it, you will see about 270HP flywheel and 235ish to the wheels. The stock 351c 2v was 250HP, but that was before net ratings, you realistically you are probably looking at 200HP flywheel and 170ish to the wheels. So yeah, I would say that would be a good jump.I swear some of you guys are crazy. Saying that the car would take a hit from $16k to $6k by adding an awesome 275 hp modern efi drive train is lunacy. I guess my dads 40 Ford Coupe with a 300 horse 327 chevy motor ruined the car as well. Not all car people care about **** being concourse correct numbers matching. Actually A Cougar guy is probably the last guy I would want to buy my Cougar. I drive my Cougar and what ever makes that experience better is all I care about, and frankly that's what most people who aren't specific model purists care about as well.
Maybe I will look at a 4.6L SOHC, but can that give me anywhere near the HP and torque that my stock 351w 2v now does?
Just curious but why not 99+ block and heads?If you get a 94-98 block and slap 99+ heads on it, you will see about 270HP flywheel and 235ish to the wheels. The stock 351c 2v was 250HP, but that was before net ratings, you realistically you are probably looking at 200HP flywheel and 170ish to the wheels. So yeah, I would say that would be a good jump.
When you use the old NPI block/pistons and PI heads, it bumps the compression ratio up and gets you about 10 extra HP. When you use a PI block/pistons, the compression is down and you get 260HP. Also, when I say 99+ heads, I mean that for the mustang heads, the rest of Ford got PI heads in 01.Just curious but why not 99+ block and heads?
Maybe to Cougar guys. I'm not a Cougar guy, I'm a cool car guy.Durf, For a Cougar convertible to get to $16K, a significant part of the value is that it is a Cougar convertible. Cougar Convertibles are collector cars, $16K is a lot of money. Typically when you see one with the wrong drive line in it, it sells for less than $5K.
