Hi All,
1/2 way through changing out my brake distribution block/proportioning valve. (Getting the booster out of the way was not fun).
Just put in the block. Since it will be filled with air and I will be re-bleeding all four corners, do I even need to bother filling the master and bleeding it before putting it on? Just trying to save time/aggravation if I don't need to.
Incidentally, the nuts holding the booster on fought me coming off the whole way, with me upside down under the dash. They were "tight" and required a ton of ratchet torque in a confined space. What is the best lubricating trick I can do to the studs and nuts to get them to spin on easier? My fingers still hurt from all the force I needed in there... my dad used to rub a dry soap bar on the studs...
Thanks!!
Calbert
Thanks!!
Calbert
