Well, I just learned the hard way.... DO NOT make the Proportioning valve cherry red with a torch to get the piston un-stuck. It tends to incenerate the little rubber check ball and nylon cap associated with the check ball. Poof! Gone! :bloated:
At least the piston came out easy after getting it hot. Too bad I can't get those two important pieces anywhere and the proportioning valve is now useless junk.
Oh well, live and learn I guess. I will now have to use the adjustable Proportioning valve that I bought for when I convert the rear to disc brakes in the future.
