The brake lights are not working along with the emergency flashers in the taillights. (The emergency flashers work fine in the front marker lights). The 15 amp circuit breaker and the brake switch both test fine, so I'm assuming my problem is in the turn signal switch, even though I replaced it with one from WCCC not long ago (tilt-a-way column). Anyone know of any other possible culprits?
Thanks,
JAMES
Thanks,
JAMES
