1 - 8 of 8 Posts
Hello All.
I am a long time lurker who rarely posts, and I could use some assistance with this.
My question is, are the 68-69 Torino and Cyclone 428 ram air assemblies the same unit used on the 69-70 428 Cougar?
My research indicates that Ford never sold the individual components, only the assemblies under part number C9OZ-9600-G.
Specifically, are the flapper tops the same part?
Any help is greatly appreciated.
Thanks, Mike H.
Mostly the same.
There are also differences between 1969-70 ram air cleaner assemblies on Cougars. The key difference being 1969 used a metal elbow for the hose to the oil cap, and the 1970 used a plastic elbow.
1968-69 Torino ram air seals are taller that the version found on 1969-70 Cougars.
The ram air seal used on the 1969-70 Cougars is the same as a 1968 Mustang. 1969 Cougar ram air is nearly the same as 1968 Cougar/Mustang R code assemblies.
CougarCJ, thanks for the reply.
The reason I am asking the question, specifically about the flaper or midplate, is that I have a buddy looking for one to go on his 70 428 CJ 4 speed Eliminator.
I have one, and I believe it to be from a 70 Cyclone.
I also believe that for the most part, they are the same item with the exception of the location tab in the front, which I think was added for 70-71 Cyclone applications, but I an not completely sure, and do not want to give this guy wrong information.
I did manage to get the last revision (1975) of the Ford / Mercury parts catalog and it does show the Torino prefix C9OZ for all 428 Ram Air applications across the Torino, Montego, and Cougar platform for 68 & 69.
The Ford doc's are a bit difficult to understand if you are not a Ford parts guy, so I am still a bit confused, but I can scan and post this info if it would be of use to the group.
Thanks, Mike H.
Some of the componentry is located here.
The 1975 Master Parts Catalog final revision is not a good source of information. It lists what replacement parts were available that would fit and work. It does not tell you what was used originally. A great example is your post saying it lists the C9OZ part for 1968.
Thanks again for the replies guys.
I do appreciate it very much.
I will check my unit against the information in the link on the 428 page to get a better idea
of what I have. That is a great link.
Mike H.
The seal on a 70 Cyclone has the front 1/3 of the hood seal cut away so is not the same.
Also, the '70 Cyclone is a 429 not a 428.
1 - 8 of 8 Posts
