I have a completely restored shifter assembly for 1969. This will include a restored control box with new correctly heat treated detent return spring, new back up light switch, original bare metal rods and levers, rechromed handle with correct jamb nut and new woodgrain knob with blue/white stripe, shift handle rubber grommets, locking bolts and correct washer spacers, New mounting plate for either 428 CJ (GT500) or Boss 429 , Mounting hardware, new Lower shifter boot. Ready to install on your toploader. If you want this for smallblock we will deduct the big block mounting bracket $895 (920) 434 36
