Quick question for you folks, what wire should I use for hot in start and run to connect my 6AL box? Can I bypass the tach and use the end that originally connected to the coil to connect to the small red wire on the 6AL box?
Thanks.
DaveK
Thanks Bill. I appreciate the help!
so Dave where did you decide to mount your box at? I'm thinking about putting mine in the passenger fender area behind the headlight location and having the wires either come around the front grill area to hook up. My other idea is to make a hole under neath the battery box to bring wires through there. just curios what you were doing?
