If its the large vacuum canister that goes on the driver's side under the fender then I can be of help. My 67, which should be the same as your 68, had it located right behind the headlight assembly toward the wheel well of the front driver's side fender. It mounts to a bracket that is already mounted to your fender unless it's been removed. Four screws hold it on and a splash shield should connect to it as well, thus blocking the back of the headlight assembly completely from view. In my 67 Cougar Body Assembly Manual (Jim Osborn) it's on pages 16 and 32. Page 32 view B has a good drawing that shows the finished product. If anything maybe you could google the manual. Hope that could help ya!
