help. Front left turn signal does'nt work. The Bulb is ok, socket is ok, can't find flasher. I sure hope it's not part of that mess in the trunk. I have a copy of a schematic someone gave me, but I can't follow it. (Normally I don't have a problem with them). Any ideas? THanks, Geo.
right front turn signal
I have the same problem. I have tried everything I can think of. all other signals work even the sequentials. the light on the dash will blink once and then stay on and only dim as the sequentials work. I tried an ohm meter and it looks like there is no power at the feed? But im not sure becouse I had to set the meter to ac to get a reeding on the right side that works well? Let me know if you get a salution
