Hi,does anyone produce the weather rubber seal that fits to the vent glass(u channel section with shaped part around the closing handle)and fits inside the stainless glass frame,the part with the pivots on.
cheers
cheers
It sounds like you are talking about the triangle shaped pieces. If so I should have them here in stock in reproduction form. I would need to double check the inventory to be sure though. Thank you.Hi,does anyone produce the weather rubber seal that fits to the vent glass(u channel section with shaped part around the closing handle)and fits inside the stainless glass frame,the part with the pivots on.
cheers
