Also, the rod the puts pressure on the spring that keeps the wheel in the selected position is bent. The spring itself maybe weak too. I am going to take the rod out Thursday if I get time. Do I just straighten it, buy a new one (if available), or make one custom? Can I buy a new spring or is the bent rod the sole reason for the loose play on the wheel? Thanks again!
The rod like a large nail, with a "T" head on it? It is not bent.
<table border="0" cellSpacing="0" cellPadding="0" width="600"><tbody><tr vAlign="top"><td width="600">
1967 - 1969 Mercury Cougar / Ford Mustang Tilt Tension Spring Rod - Used
<table width="600"><tbody><tr vAlign="top"><td width="300"><center>
<table align="left"><tbody><tr><td align="center">[URL="http://ep.yimg.com/ca/I/yhst-11089400041767_2176_143915216"]
</td></tr><tr><td><center>
Click to enlarge</center></td></tr></tbody></table>[/URL]</center></td><td width="300">
<table border="2" cellPadding="5"><tbody><tr><td><form id="yfc_1" method="post" action="https://order.store.yahoo.net/yhst-11089400041767/cgi-bin/wg-order?yhst-11089400041767+q2c60">Print This Page
Bookmark Page
Availability:
Usually ships the next business day
Orderable?
Part #: 1000039
[FONT=arial, helvetica]
Price:$29.00
<input name="vwitem" value="q2c60" type="hidden">I Need to Order: <input name="vwquantity" maxLength="3" value="1" size="3">
<input value="Order Item (add to cart)" type="submit">
<input name=".autodone" value="http://www.cougarpartscatalog.com/q2c60.html" type="hidden">
</form>
</td></tr></tbody></table>[/FONT]</td></tr></tbody></table></td></tr><tr><td width="600"><map name="3af04e9477f81403"><area href="http://ep.yimg.com/ca/I/yhst-11089400041767_2176_216925493" shape="rect" coords="0,0,175,131"></map>
Description:
Don't try to straighten your rod if it looks like this. The contour seen here is correct.
</td></tr><tr><td><table border="0" cellSpacing="0" cellPadding="0" width="600"><tbody><tr><td>
<!-- Yahoo Related Items Div //-->
<!-- End Yahoo Related Items Div //-->
</td></tr></tbody></table></td></tr></tbody></table>
