Tilt column pulled from a 67 Cougar. Has vacuum motor, vacuum release valve, brackets, vacuum canister, rag joint, door switch and turn signal switch. May need rebuilding as it was not connected and came from a non running parts car. Fairly complete, I did my best to pull everything. No obvious damaged / broken parts.
