My '67 has just started starting with the key in either the ignition, start or accessories position in the switch. When I turn it to accessories, as well as firing, the starter remains engaged. I just fitted a new ignition switch, key and barrel set because of this, thinking it might have been a faulty ignition switch. All I have done is to solder a new wire from the green/ red terminal at the switch as a hot wire to run an igniter ll which I am trying to install. It does turn off ok, for what that's worth! Is it possible I created a short while making a hole through the firewall grommet for the new igniter wire?
Thanks for your help!
Peter Lynn
Peter Lynn
