Ok, here we go again. Can anyone tell me if the 2 brackets are the same for the tank under the drivers fender for the headlights? Also, is the hose fitting supposed to stick out the front or the back? I installed the 2 brackets as I thought they should be and I can only get 1 side to line up with the mounting holes on the tank. And if I mount the tank and the fitting is facing forward, then the headlight bucket covers it (So I think it should be pointed inward. Thanks in advance, you've all been great.
Steve
Steve
