67 CATATONIC TRANS AM VINTAGE RACER
289 ENGINE BASIC PLAN
THERE ARE TWO VERSIONS OF THE 289 FOR TRANS AM.
TWO 4'S AND A SINGLE 4. BUD MOORE USED THE TWO FOURS AND SOME INDEPENDENTS USED A SINGLE 4 BBL. SETUP. I AND USING THE SINGLE 4 SET UP AS I WILL SAVE APROX. 12 POUNDS AND ABOUT $400. MUCH EASIER TO TUNE AND DELIVERS ALMOST EXACTLY THE SAME HORSE POWER. MY ENGINE WILL BE A VINTAGE HOLMAN AND MOODY POWER PLANT.
EAGLE RODS
12:1 COMPRESSION
HOLMAN AND MOODY DUEL PLANE SINGLE 4 INTAKE
1967 HOLLEY #4742 CENTER SQUIRTER 600CFM CARB
H/M ALUMINUM PENTROOF VINTAGE VALVE COVERS
HIPO 289 FOMOCO ALUMINUM WATER PUMP AND FRONT COVER
PORTED, POLISHED CAST IRON HEADS ( ALUM. NOT ALLOWED )
DUEL POINT DISTRIBUTOR ( AUTOLITE OR ACCELL )
ALUMINUM RADIATOR, AUTOLITE BELTS AND HOSES
MANUAL STEERING AND BRAKES
LAKEWOOD BLOWPROOF BELLHOUSING AND COMP. CLUTCH
TOPLOADER 4-SPEED TRANSMISSION
ALUM. DRIVESHAFT
DETRIOT LOCKER REAR, MOSER AXLES, 4;11 GEARS
RAM AIR, DISC BRAKES, 70 BOSS 302 FRONT END
LOWERED AND RACE PREPARED SUSPENSION
I GUESS THAT ABOUT COVERS IT SO FAR. THE ENGINE WILL DYNO AROUND 400 HP. TRANS AM RACING IS ALL ABOUT SUSPENSION AND DRIVING SKILLS.. IT WILL BE TOO MUCH FUN.
IF I BUILD IT, WILL THEY COME???? OF COURSE!......
[email protected]
67 GT VINTAGE TRANS AM RACER 289 4-SPEED
69 SPORTS SPECIAL 351W DAILY DRIVER
69 CONVERTIBLE 351W CRUISER/SHOW
