1 - 2 of 2 Posts
Hi i just swap out my c4 auto to a manual top loader tranny so far so good, but the clutch rod i bought is a 67-68 its straight then it angles, was wondering which ends goes to the z-bar and which end goes to the clutch pedal.
also it looks as thow i will need a spring form the clutch fork to lower z-bar arm a #7591
at wcc and a uppper spring from upper z-bar arm to firewall with a bracket that bolts where the parking brake studs come through firewall does this sound correct ?
thanks
Eric
From memory, I believe the bend in the rod faces upward and the ends that go into the pedal/bar face right. On the springs, correct that there are two but can't speak for the firewall bracket as 69/70 (what I know) clips onto a loop built into the firewall.
1 - 2 of 2 Posts
