I just pulled the front suspension off of my 67. I am not sure if it is original, although the UCA's have bolt in ball joints. The LCA's have the jack tabs underneath. They are dirty and need ball joints at minimum. I also have the 5/8 inch sway bar and brackets with new rubber, a good set of drum brakes that I put new pads and hardware on and then never drove on except in an out of the garage onto a trailer and them back again. The drums have no hubs. The inside of the drums have no noticeable wear. A pair of stock height springs maybe original with stapled on rubber cushions. Maybe something to rebuild on a bench to reduce your downtime. Happy to take pictures if there is any interest.
I also have:
a nice 68 xr7 console base for an AC car
a nice parchment deluxe windlace pair with a nick that should be invisible installed
68 console base pad in saddle
67 parchment pads in excellent shape
What is diff between AC console base and non AC? I am interested if the AC will work in NON AC fairly close.
The ac consoles are cut on the back and do not reach as far under the dash because part of the ac box occupied this space. You can put an ac console in a non ac car but not vice versa without modification. Look here.
http://www.cougarpartscatalog.com/c7zb-65045b54.html
Cool. How much for the base. You are talking about just the plastic bottom part correct? Can PM me or reply here ur pref.
