Hello everyone. I have alot of Cougar parts for sale. Here is a list of the things I have.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]-->
Make me an offer on the part you want and we can go from there. Thanks for looking.
Greg
- 1 Left and right door panel
- 1 Left and right rear panel
- 1 right headlight assembly
- 3 2-bbr carbs
- 1 4-bbr carb
- Upper and lower 5.0 manifold
- Steering wheel (some cracks)
- Steering wheel adapter
- Hood latch mechanism
- 4 ashtrays
- 3 left front fender extensions
- 5 left rear fender extensions
- 1 right rear fender extension
- 2 oil gauges
- Distributor
- Radio bezel
- Headlight vacuum pump
- 2 sway bar bushings
- Center grill insert
- 4 center grill emblems
- Automatic shifter with bezel
- 4 headlight buckets – 2 with vacuum pumps, 2 without
- Battery Tray
- Misc Brackets
- 4 bumber guards – 2 front, 2 rear
- Rear wiring harness with sequential box
- Fly wheel
- Air cleaner assembly
- 2 sets of seat tracks
- Trunk lid
- Mustang instrument panel
- Interior window trim – 2 white, 2 black
- A/C Pulley
- 2 right side headlight doors – 1 with emblem, 1 without
- 3 left side headlight doors
- Set of leaf springs
- Headlight cone
- Headlight trim ring
- 2 headlight trim panel
- Set of shock tower braces
- Wiper motor with bracket
- Scatter shield
- 13 horns – 7 left, 6 right
- Exhaust hanger
- Jack, handle and 3 hold downs
- Coil
- Thermostat housing
- Oil pan – 22 bolt
- Oil dip stick and tube
- Transmission dipstick tube
- Crank breather
Greg
