<link rel="File-List" href="file://localhost/Users/student/Library/Caches/TemporaryItems/msoclip/0clip_filelist.xml"> <!--[if gte mso 9]><xml> <o
ocumentProperties> <o:Template>Normal.dotm</o:Template> <o:Revision>0</o:Revision> <o:TotalTime>0</o:TotalTime> <o
ages>1</o
ages> <o:Words>591</o:Words> <o:Characters>3370</o:Characters> <o:Company>UW-Stout</o:Company> <o:Lines>28</o:Lines> <o
aragraphs>6</o
aragraphs> <o:CharactersWithSpaces>4138</o:CharactersWithSpaces> <o:Version>12.0</o:Version> </o
ocumentProperties> <o:OfficeDocumentSettings> <o:AllowPNG/> </o:OfficeDocumentSettings> </xml><![endif]--><!--[if gte mso 9]><xml> <w:WordDocument> <w:Zoom>0</w:Zoom> <w:TrackMoves>false</w:TrackMoves> <w:TrackFormatting/> <w
unctuationKerning/> <w
rawingGridHorizontalSpacing>18 pt</w
rawingGridHorizontalSpacing> <w
rawingGridVerticalSpacing>18 pt</w
rawingGridVerticalSpacing> <w
isplayHorizontalDrawingGridEvery>0</w
isplayHorizontalDrawingGridEvery> <w
isplayVerticalDrawingGridEvery>0</w
isplayVerticalDrawingGridEvery> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w
ontGrowAutofit/> <w
ontAutofitConstrainedTables/> <w
ontVertAlignInTxbx/> </w:Compatibility> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="276"> </w:LatentStyles> </xml><![endif]--> <style> <!-- /* Font Definitions */ @font-face {font-family:Cambria; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 0 0 0 1 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Cambria; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> <!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin;} </style> <![endif]--> <!--StartFragment--> Most of the stuff will be for 67 68 cougar/ mustang, GS 550 parts, 95 buick parts
<o
> </o
>You can reach me at 715 505 5007
65-6 mustang coupe roofside raile weatherstrip also fits 67/8 cougar
68 console pad top front radio holder w/ clock
67 console bracket front radio has sliding door opening but no door
67 68 cougar quarter window chrome behind DS door
67 68 cougar quarter window chrome behind PS door
67/8 cougar auto console sider with light complete
302 351 windsor thermostat housing with elbow and vac advance
P/S bracket
68 manual drum brake distribution block
68 front drum brake setup complete and rebuilt and painted
alt brackets
wipers 67 68 cougar
A/C canister
Master cylinder covers power and manual
67/8 cougar horns hi/lo
68 auto console cover plate chrome
bellhousing inspection cover
67/68 302 289 2bbl carb spacer 2v
fuel rails
nose chrome 67/8 cougar
front bumper filler DS front
oil pressure gauge sending unit PS – 60
throttle bracket
67/8 xr7 dash one good with toggles
woodgrain inserts for entire dash
xr7 badge
A/C vent xr7 and non
67 cougar disc brake setup complete would need rebuilding from ball joints to brake lines
distribution block disc
351W distributor crane cams XR-I vac advance
K/N breathers
67/8 mustang rear chrome valance bumprettes
750 holley dominator L 80186 rebuilt with K/N air cleaner and adaptor
front license plate bracket
rearview mirror 67 red deluxe
DOQE 1970 351W Windsor 4V closed chamber heads $125
DOAE 1970 351C Cleveland 4V closed chamber heads $350
3.8 buick motor complete disassembled partway 1995
3.8 buick heads 1995 2136 DO64 6mpt 4
T5 E7ZR – 7003 – AA REP AP 13- 52 – 162 103013 F2182
T5 F0ZR – 7003 – AA REP AV 13 – 52 – 199 49211 00603
95 3.8 exhaust manifolds intake manifolds plastic complete
9” housing 71-73 mustang 2” wider than 67-8 mustang cougar
302 2V intake C8AE – 9425 – B
’72 Windsor crank and Pistons 351
metal nose piece cougar
Upper and lower door hinges
Vac pod headlights
Rear license plate bracket
Steering column support
Door catch
p/s pump
crank pulley 2 groove 4 bolt crank
bracket LW E 0187
Headlight cover for adjustment
Vac box bracket
Slider for door glass
Gas filler with cap
Valance light retainer
Am/fm radio 4084017 – 0001 ford stereo
Cowl vent repair kit plastice new
Dashes xr7
Draw tite trailor hitch cougar 67/8 chrome
Kick panels
Air shocks 67 / 68 cougar
Vac tank
Bellhousing similar to T5 but for 4 speed newer clutch D9ZC 6394 BA
Throwout art T5
C4 Cross support with trans mount
1978 suzuki gs 550 carbs
cougar D/S glass all three pieces
long black seatbelt retractor
302 air cleaner assemblies snorkel
painted 302 valve covers stamped steel
95 buick headlights glass and side markers front
93 jag headlight
C4 tailshaft support like driveshaft loop
Glove box good shape
Ash tray
3.8 spark plug wires new
taillights cougar
p/s fender with extension
front valace
302 oil pan
1980 suzuki GS750 550 seat cover with foam
90 ranger yolk yoke
seatbelts aqua 2 short retractors and 2 lap clasps
black set seatbelts complete with shoulder straps
Mallory distributor 5055401H bronze gear 351 windsor
Mallory 3755401 large pin 351W distributor works great
Accel 8.8 wires black
Mallory 3755101 H unilite 302 works great
Mallory voltage spike regulator
68 non power master cylinder
302 or 351 intake exhaust gaskets valve cover gasket in box
3.8 intake valve new
washer bottle
D/S vent with cable plastic
d/s p/s quarter window sliders an dsmall channels
D/s p/s a pillar pad 67
Trunk hinges
Trunk rods
Front shock caps
C4 inspection cover
Exhaust hanger factory cougar
Spare tire hold down
Manual air box non ac with defrosters complete with paper piece
Non ac cable heat adjuster controls
Cowl cover
Auto non power brake pedal
Gas pedal pad
Roof rail chrome
Headliner bows
Trunk lid chrome
Trunk tension rods
Fuel line framerail by engine bay
Windshield chrome
Hood chrome
Rocker aluminum
Back glass
Front/ rear valances with lights
Front rear mercury scripts and cougar emblems
69 cougar front grille chrome center
GS550 motor with kickstart 78
Pretty much complete but disassembled 78 suzuki gs 550
Gs 550 frame
cougar rear glass
complete front headlight assembly
67 or 68 289 or 302 complete
<!--EndFragment-->
<o
P/S bracket
alt brackets
wipers 67 68 cougar
A/C canister
fuel rails
throttle bracket
xr7 badge
K/N breathers
Vac pod headlights
Door catch
p/s pump
bracket LW E 0187
Vac box bracket
Gas filler with cap
Dashes xr7
Kick panels
Vac tank
Throwout art T5
93 jag headlight
Ash tray
taillights cougar
front valace
302 oil pan
90 ranger yolk yoke
washer bottle
Trunk hinges
Trunk rods
Front shock caps
C4 inspection cover
Cowl cover
Gas pedal pad
Roof rail chrome
Headliner bows
Trunk lid chrome
Trunk tension rods
Windshield chrome
Hood chrome
Rocker aluminum
Back glass
Gs 550 frame
cougar rear glass
<!--EndFragment-->
