I bought a 4 speed toploader setup from a 1967 Mustang last summer. I am about ready to install it in my 1968 Cougar. It has an automatic right now.
Does the toploader bolt right up? I guess more specifically, what will I run into that needs to be altered? Does the shifter go through the same hole in the floor as the automatic? I am pretty sure that the hole will need to be punched in the fire wall for the clutch pedal. Is it obvious where it should go? Has anyone done this before? What "gotchas" should I avoid?
Thanks in advance for all your help. This website rocks!
Dave
Dave
