Well, I figured this thread was as good as any to post in, of all the threads I've read on here about this topic, before I start a new one! Hopefully I can get some insight!
I have a 68 Standard with 302 2v all stock except the Pertronix ignition. Did the 3G upgrade with a 1995 mustang 3.8L V6 Alt and it was charging at 15.09 volts at idle. The alt has the stock harness that goes with it, along with the 6 gauge power lead with the fuse-able link in it. Everything is hooked up correctly according to the schematics that's been posted around. Yellow wire to B+ on solenoid, white wire plugs back into the alt, and the green/red wire to the 904 wire from the old regulator harness.
Battery charged up to 13.8 volts when I shut off engine after running for about 5 min. I didn't wanna cook the battery so I re-read all the posts about this upgrade.
With that said, I have since replaced all grounds and power leads with 4 gauge wire and a 175 amp mega fuse. Alternator to block, firewall to block, chassis to block, battery to block, Alt power to solenoid, and Battery to solenoid, have all been cleaned, tightened, and ohm out at .001/.002.
I had the alternator tested at two different places and it came in 14.2/15.4/16.8 on the print out. Passed both times.
I also thought that maybe the field was high, due to sensing that the battery was low due to the fact that I've started the 68 multiple times between rebuilding the P/S pump and this upgrade without actually driving it and giving the battery a full charge, so I charged up the battery with my wall charger. It pulled 8 amps and slowly dropped to 1, and it sat at 13.4 volts.
After all that, alt now reads 15.04 volts when running. Disconnect the 904 wire and the voltage drops to the battery voltage (currently 13.1v), plug it back in, and back to 15.04 volts it goes.
Is this correct? Acceptable? Will it cook my battery? (Also, my ammeter doesn't light up at all after the change) (turn indicator light doesn't blink inside, but they didn't really before either)
Any insight would be appreciated!! Thx!
