1 - 8 of 8 Posts
Hey guy's I'm tired of listening to the exhaust leaks on my 390 on the tops of #3 and #7 so I'm taking them off to get machined to see if that helps.I've got the passenger side off,but not out yet.I've got 4 bolts off the drivers side but I'm having a bear of a time getting at the ones by the shock tower.do I need to unbolt the motor mount and jack up the engine on that side?my back was getting a little stiff so I called it a day and will get back at it tomorrow.
Terry
That is how I do that job!
Just be sure to not use gaskets when you put it back together. They always blow out. There were no gaskets originally, and none are needed.
When you are dealing with a big block in a Cougar, there is no EASY way. Just to add to what Royce said, both surfaces must be machined in order to not need gaskets. Good luck.
Actually I have never had any of the surfaces machined. Sometimes they have been pitted from rust. I do clean them thoroughly with a wire wheel if the parts were not sandblasted or vatted first. They can be pretty badly pitted and still seal off perfectly. A light smear of the cheapest RTV you can find works fine, although I have also used Permatex #1 or #2 and silicone bathtub caulk with equally good results.
Discussion Starter #7 (Edited)
I used ultra copper on the leak on #3 last year and it held up until I fired it up this year and it started to leak again that's why I'm pulling both off to get them trued up.Can I run a belt sander over the ports to true them up or should I leave that to the machine shop?
You need to be sure the manifolds sit flush on the heads. Use whatever means are necessary to achieve that goal.
1 - 8 of 8 Posts
