Depends...if everything is stock, the timing pointer on the post '70 351w's is on the pass side..everything else, early small block wise is on the drivers side. What has been changed?
You need to get a 1969 351 Harmonic balancer so the engraving will be on the correct side to use the timing marks.
Maybe - look in the performance section with the Mr Gasket goodies....
