Just found the casting numbers on the block (F4TE-6015-AA-18) and that tells me I have a 1994 engine.
Went to Ford to buy the timing marker and they told me the marker bolts to the timing cover on the drivers side. It sounds right because there is no room on the passenger side due to the hose on the water pump is in the way and you can't see the HB. As I was leaving the parts dept. a mechanic said the marker is on the passenger side and it's real hard to see.
Who is right? Can't find anything with a google search and I don't want to open the part bag cause they won't take it back.
Engine is not running or I would hook up the timing light to see which is closer, left or right.
