I'm in the process of putting a fresh 351w in to our '69. As far as I know the 351 came out of a 79 crown vic police package. I know this decoding the codes. It has a dual sump pan with 2 drains. I'm having trouble getting the rear hump to clear the power steering control valve? Its the shock looking thing that connects to the front drag link. I've tried using the original pan from the '69 but the front sump isn't deep enough to clear the oil pump. I'm thinking about removing the PS control valve? to see if I can can the clearance for the dual sump pan. Also thinking about removing PS all together as the system needs rebuilt. Has anyone used the Power to Manual steering adapter from WCCC? I'm just looking for some more info from you guys on the 351w and maybe its differences from the regualar 351w. I'll be researching it yet to as I want to get this set in before the snow flies. Thanks for you time. 6t9
