1 - 1 of 1 Posts
'69-'74 Ford 351W Windsor Partial Engine Gasket Rebuild Set - Incomplete
These gaskets are left over from when I installed new gaskets and seals for my valve covers, intake manifold, and oil pan 5 years ago. Since that was all I did, these parts have remained untouched in the box stored indoors ever since. This is NOT a complete set. As far as I can tell these are the items remaining, but ultimately what you see in the picture (on eBay) is what you get:
2 Cylinder Head Gaskets (lying on top of each other in pic)
2 Exhaust Manifold Gaskets
1 Fuel Pump Gasket
1 O Ring
1 Oil Pump Gasket
2 Oil Pump Inlets
1 Oil Pump Mounting
1 Rear Main Split Seal Assembly
16 Valve Stem Seal
1 Water Pump Gasket
1 Water Neck Gasket
1 Oil Plug Gasket
Pics of the Kit are on eBay right now-- NO RESERVE!! :ylsup:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190385250096&ssPageName=STRK:MESELX:IT
1 - 1 of 1 Posts
