The 70 allows for the MUCH bigger exhaust manifolds.So what are the differences between the 351c z bar and the 351w z bar besides the part # DOZZ-7528-D and C9ZZ-7528-A? thanks
I have a similar bar myself (from a '70 351C) but I laminated a thick piece of bar stock onto the part you have the angle iron on and welded. Which is also why I bought a (351W) repro when I did Isabel (and went to a CF dual friction diaphragm clutch which doesn't kill clutch linkages like a HD Long style clutch does). I have not seen a 351C-specific repro.Here is a pic of my 351c Z bar -- note: it has a piece of angle iron welded on to it.
Hope it helps.
Was on a road trip for WCCC, will check and report Monday or Tuesday.So Scott, Does your bar look like the one pictured. I found a bar but it looks different. Also the one pictured looks like what I see for the 351w? Maybe I should just hydraulic or cable.
