1 - 11 of 11 Posts
I own a 1971 cougar with a 351 Cleveland 2v, to upgrade my performance my guess would be to throw on a 4 barrel carb and a 4 barrel intake, I read you weren't supposed to put a 4 barrel intake, on a 2v Clevnd is that true? If so is there a way to add a 4 barrel carb with a 2v intake, also would an efi system be even more powerful and efficient?
There are several aftermarket 4v intakes for the 2v heads. Edelbrock Performer is probably the most popular. EFI would be totally custom for the cleveland. A 4v intake and carb and you will be doing just fine.
You shouldn't use a factory 4V intake on a 2V since the ports on a 4V are HUGE and will be a mis-match to the smaller 2V ports in your heads. Aftermarket 4-barrel intakes that are made for the smaller 2V port size are just fine. Use a 525-600cfm vacuum secondary carb and you're good to go.
True about the port mismatch putting a Ford 4V manifold on 2V heads, but people used to do it before aftermarket 4V for 2V heads manifolds became available. A non-optimum and now obsolete mod, but people did do it and it worked, how well I don't know. One would use 4V gaskets if one were to do this.
Fuel injection is now out there for the Cleveland. http://www.summitracing.com/parts/TFS-51600118/ Pricey, but there. It would just be a matter of collecting parts, but I wouldn't say it is a total custom setup. It could be done much cheaper with one of those injection thottle bodies that look like a carb though.
To the OP, if you can handle some other mechanical work, a cam/timing chain replacement would be you next biggest bang-for-the-buck. Nothing outrageous, either. Just a cam like the cheapie Summit cam/lifter kit works wonders in a Cleveland!
Not for nothing, but a 2V Cleveland is just fine with the right stuff, in fact best on the street (vs. 4V) in my opinion.
I will attest to that.
Not only that, but I have seen side by side dyno numbers of the same engine, but with heads swapped between pulls, and the peak differance was only 10 horses and somewhere around 20 lbs/ft of torque.
1 - 11 of 11 Posts
