AOD
The AOD is almost a bolt in swap. I put one into wvcat last winter with only minor obstacles. First my car is a 70 but the swap should be the same. Ok here goes, the AOD will bolt right up to your block but you will need the block plate and converter to go with it. Iwas able to reuse my stock FMX flywheel with no modifications. The starter bolts are in the same location but the top hole will have threads on the block and the starter. I drilled my starter housing hole out and reused my existing starter. One of the FMX cooling lines line right up the other is too short. The stock shifter can be reused but it has a different amount of travel. Mine worked out with park in the normal position and low in the second position. The stock speedometer cablelines right up but you will have to change the gear to match your gear ratio. I am using a 21 tooth gear with 3:73's and 275/60/15 tires. My driveshaft also worked but you will need the yoke that matches the AOD or one from a toploader. Thats all the easy stuff, heres the challenge. You will need to fabricate a crossmember,I made mine out of 1 1/2 square tubing. I also know someone that makes them but his wouldn't work with my exhaust so I made one.
One more thing.... when you buy the trans get one from a 89 or newer stang with a 5.0. The newer transmissions have improved oiling and the stang trans has the correct lever on the side but it will need pulled out and rotated 180 degrees. The only thing else you need is a throttle cable, I am using a lokar cable(69.95 at you friendly speed shop). I also installed a bauman engineering shift kit.
If you need any other questions answered I'dbe glad to help.
John
wvcat
http://www.geocities.com/wvxr7cougar/wvcat_01.html
