I've got may new engine in, but ran into a few questionables. For some reason, I cant get it timed right. I have the Distributer turned completely turned clockwise against the water outlet, and it runs pretty well that way, but I know its not right. What can I do to fix this? Its kind of throwing me off a little. And also about how much fuel pressure should I have going to my Holley 4160 600cfm carb? I think I have it set at about 5psi maybe 4.5. When I took my test ride yesteerday, I left tire tracks at all 4 corners going around my moms block, but I Know I can be getting much more than I am right now. Also what temperature thermostats are you guys with the 302's running? Thanks in advance.
