Hi, I'm looking for the stock pulleys of an early 302 (water pump and crank pulleys). This engine only has a steering pump, so I'm looking for the dual groove on both the water pump and crank pulleys. Thanks
4 bolt, but check this out. A tech told me I could take all the serpentine pulleys off an 88 bronco 302 eFI, as long as I take the water pump with them (for obviuos reasons), and convert this 1970-1975 302 to a serpentine system. What do you think?
I'm sure it would probably work just fine as long as your running the same # of accessorys. Maybe you need the accessory brackets also? mm
