Suddenly (no logical reason) I can't get fresh air into the car without it being heated. In fact, no matter what control setting I choose...including a/c...brings me ONLY Hot Air!
I'm thinking the air-flow "blend" door is stuck or there's a valve controlling heated radiator fluids stuck in the "open" position. Anyone with other thoughts? Confirmations? Thanx. Jay.
Not real sure about the "newer" cougars..but, perhaps is this problem vacuum related?? Did you do anything recently that "might" have popped a vacuum line off under the dash or under the hood? Is the glove box crammed with junk that could have knocked something loose behind it? Just throwing a couple of ideas out there for you. If it were a 'CHEEBY" I would say the drivers side "windbag" was your problem.
If the 94s have the same basic componentry as a Taurus, the heater blend door actuator may be faulty. It is an electrical solenoid that can be replaced fairly easily (in a Taurus anyway).
