1 - 2 of 2 Posts
Problem #1
always seems to over heat
going to flush radiator & replace thermostat and test fan
*what is the best procedure to flush this cooling system?
*what might cause the fan not to work?
*how much coolant does the 84 xr7 hold?
Problem #2
brake pedal goes straight to the floor, but if pumped a few times, pressure comes back *does this mean there is air in the lines/need to bleed brakes?
*Brake bleeding procedure?
Problem #3
the heater fan makes terrible noise and is easily off balance
*procedure for replacing heater fan?
sorry for all the questions, I'm used to working on Subarus....
Thanks in advance!
Step 1: get a copy of the factory shop manual.
Cooling system capacity is in the owner's manual.
1 - 2 of 2 Posts
