I wondered if there was instruction on line for Alternator replacement on my car? I dont do engine work and I cannot afford to have someone make the repair. Is this easy?
Thanks
Thanks
Very wise words, but to add a little more, when reconnecting, connect the positive cable first. If you think of how electricity works, it make sense to do it this way EVERY time. If you disconnect the negative first, the only way it will short is if you short to the positive lead of the battery. If you were to take the positive off first, EVERY thing that your wrench could touch would be negative and would scare the crap out of you and possibly cost more money in replacement parts. Once the negative side of the battery is off, this is no longer a concern. Same goes for when you reconnect.Disconnect the negative battery cable FIRST.
