Just pulled my tranny out it has the original tag on it it says PHB H C9ZB D210,Is this a cougar transmission or mustang? i belive its an FMX but is it origional ?
Thanks
Aaron
Thanks
Aaron
According to the code on the transmission tag, it's for a '69 351-4V (BTW, what is the engine code to your car, it would be the 5th character in the VIN). But, not to get down, look somewhere (not sure exactly where on an FMX) perhaps along the top of the transmission case for a partial VIN stamped on it (0Fxxxxxx) and see if it matches the VIN to your car. Good luck.So would this be an origional FMX tranny for my 1970 cougar right?
Thanks Alot
Aaron Huffman
I found the numbers 9T0223 stamped in the top of the case where the case bolts to the bellhousing. right above the bolt stamped in.According to the code on the transmission tag, it's for a '69 351-4V (BTW, what is the engine code to your car, it would be the 5th character in the VIN). But, not to get down, look somewhere (not sure exactly where on an FMX) perhaps along the top of the transmission case for a partial VIN stamped on it (0Fxxxxxx) and see if it matches the VIN to your car. Good luck.John
9T0223 would be out of a 1969 Mustang built in New Jersey. Your transmission is not original.I found the numbers 9T0223 stamped in the top of the case where the case bolts to the bellhousing. right above the bolt stamped in.
