So this last week I nearly had a car fire when my tired old ignition switch decided to turn into a torch. The column started smoking and I lost my dash gauges as well as having a really hard time keeping the car running. I limped it home and took the cover off the column and found my switch crispy but the wiring harness was still in tact.
I figured no big deal it should be the same as a Mustang etc. Well after an hour or so of searching the interwebz I come to find this is a 1 year only switch that has not been produced in years.
So I start searching this forum and a few mustang forums looking for solutions. What I gathered is you could take a 71-72 Cougar/Mustang ignition switch and swap the pigtail.
I am here to tell you it works. After a little time with the wire cutters and crimpers I took the old pigtail off my smoked switch and installed it on the new switch and now the old girl is back on the road.
I just wanted to share my little bit of good fortune with my fellow Cougar owners.
So if you have a crispy ignition switch you can grab a $30 71-72 switch and make the fix as long as you have a good '70 pigtail. :burnout:
