Having problem with timing advance.....going way past 30 degrees. New springs didn't help. Any one know whats up?
Thanks good stuffput a vacuum gauge on the engine and advance to best vac @ idle---shut off engine and wait 5 min ---if it bogs when you try to restart , retard a couple of degs -take it for a spin---if it doesn't ping , leave it alone
doctordesoto
Now that makes sense thanksSome factory distributors go way past 50* total.
I use an adjustable vacuum advance and weld up the advance limiting slot to limit total advance to around 36-40*
If you have a stock cam, Use a stock thick spring and a weak spring. Adjust to 10* initial.
Or you could buy an aftermarket distributor that has an easy adjustable advance curve.
Or use a degree wheel attached to the timing lobe/reluctor shaft. 1 degree distributor = 2 degrees crankshaftYou can experiment with tape to build up the area till you get the advance you want and then cut the tape off and measure it. Weld up the area ti match the thickness of the tape and your done.
Hey Art,Or use a degree wheel attached to the timing lobe/reluctor shaft. 1 degree distributor = 2 degrees crankshaft
Sure!Hey Art,
Can you give more detail to how this is done, sounds interesting.
Wow, super crafty!!Sure!
Use a degree wheel that is commonly used to degree camshafts. Clamp the distributor in a vise, figure out a way to hold the lower shaft stationary. I drilled out a short 1" bolt to slide over the reluctor shaft, then the degree wheel would drop over the 1" bolt and be secured by a 1" nut.
Fashon a pointer from an old coat hanger, clamp to the vise with vise-grips, clamp or whatever.
Move the reluctor shaft and read the degrees of movement from the wheel.
art where do I buy it how much ?Some factory distributors go way past 50* total.
what is [dizzy]? BEEN AROUND A LONG TIME....NEVER HEARD THAT WORD.New springs??? What are you running for dizzy? Did you have it out? Sounds like you are off a few teeth......double check TDC/correct stroke/pointing to #1. Also verify plug wires/correct order.
