I am wrapping up the brake project. Finished the rear drums, spring kit and piston on both sides. Finished the drivers side, need to replace both boots on the passenger side. They are totally disintegrated. No luck with NAPA, Pep Boys. Advance Auto is ordering a complete rebuild kit Not sure if these are even it that rebuild kit. If not I can return it.
Any ideas where these boots can be obtained? Any info would be helpful.
Thank you in advance.
The caliper kit consists of the square rubber ring that seals the piston and the dust boot. The rubber grommets with the booties for the end of the caliper bolts come in the caliper hardware kits. Hope this helps.
Yes this does help. I'll have to look into what comes in at Advance Auto and go from there. I was totally looking forward to getting this all together today. Bummer
