Howdy all,
Current setup. Factory 3 speed, manual 4 drum brakes, manual steering and 351w pleasantly modified.
As winter aproaches I am looking at a project to keep me busy for a few months. With my back injury the manual Z bar clutch on my factory 3 speed is just too dificult to push over and over durring an extended outing. Plus my clutch needs replaced anyway so I want to inveatigate options. Also was looking at the Borg power steering kit and it will not fit with my Z bar. Lastly the gear ratio in the 3 speed makes for some epic torque and burn outs. However, highway driving is not a pleasure. High RPM at 65 plus. Not a good highway setup.
Options
1. Replace the clutch and whatever parts are worn on the 3speed and look into a hydraulic clutch conversion. This allows me to keep the original setup and lighten the left foot preasure. However it does not solve the highway issue and I still need to shift often. Also, the 3 speed does not like to go from 1st into 2nd at higher RPM so an all out race just does not happen.
2. In my stock pile of parts I have a rebuilt FMX, drive shaft, shifter and all the parts to do an FMX swap. However I do not want to loose the performance of my clutch and manual trans. The FMX would make cruz nite a lot softer on my back. A vert us not ment to be a drag car. I have an H code coupe for that. Here I gain extra gears for highway driving, lighten the shift preasure and retain my epic burnout show off fun. But I must shift and that will be an issue over time.
3. I have a rebuilt T5 with no shifter, back plate, bell housing, clutch and on and on. So I would need a good $$$ worth of parts to complete that swap. If I go this route I want a hydraulic clutch to make shifting as easy as possuble. That also gets rid of the Z bar and makes room for the borg. With this option I get extra gears for highway driving and retain my burnout showoff fun. But over time the shifting will agrivate my back but be less due to hydraulic clutch.
So, who has done either of these and what was you experience and parts list? My thoughts are leaning to the FMX because I want to cruz not drag. But I will still need the info on the T5 for my coupe as it progresses so all input is apreciated.
Thanks
Options
Thanks
