I have a 1969 tilt-tilt away steering column that is a complete set up. The column is in original condition. The column comes with the underdash mounting bracket, cable actuator, wiring harness, vacumn canister and one-way valve, and the tilt rag joint. The door jamb switch was damaged so it will need to be replaced but this is available from cougar vendors for around $15 bucks. I am asking 675 for the complete set up. Thanks
