Sorry to all for the delay. :uhoh:
Serious personal financial issues had put the kit on hold.
Things are turning around, finally, so I am back at it again. :smoke:
I wasn't comfortable making a kit and selling used motors as part of it.
Motors would be coming from everywhere and it is hard to warranty a used part.
The 69/70 setup was pretty good, but the 67/68 setup was pretty involved - lots of pieces.
So............., I changed directions on the motor setup.
I have turned my efforts to make a headlight cover motor that would look 99% stock and use all new parts. Self contained in a "can", like the original vacuum motor.
After digging up a 69/70 vacuum motor and a 67/68 vacuum motor from my parts collection, I got all the measurements I needed and drew the "cans" up in AutoCAD.
I have spent month and months searching for motors that were strong enough to open and close the covers and yet small enough to fit inside the "can". Then finding/designing the nessesary parts and pieces to get the movement needed. Finding controlers to get the 2-way adustable movement required. Each time I would get the technical drawings from the manufacturer and check to see if I could make it fit and operate inside the "can".
I have several 69/70 setups that "could" work, but would require mutiple parts to be tooled and manufactured, thus driving the cost up. Also, the complexity of the gearing design would be a concern for wear/failure over time. Plus, It seemed like everytime I found a motor that would work, it was discontinued by the manufacturer.
This is a slow process. I will find items that I think will work, draw them up and place them inside the can. Get them situated and figure out the mounting. Then I will let it sit wor a week or 2 and roll it around in my mind. Over that time, I usually have an idea on how to improve the design or simplify it. I then go back and tweak it to the new setup.
Yes, lots of "duh" moments.
I have multiple designs drawn up, all evolving to my latest design. Availablity of parts, manufacture of parts, wiring, assembly and cost allways figure in.
I have finally found a motor that I believe will work and is actually available. It is ordered, but won't ship until late August (go figure).
I have a motor controller with built in limit circuits in hand, along with the required switches.
I am tweaking the frame to hold it all together. Getting it auto-plasma cut, but there are limits to what the plasma cutter can do. These are small pieces I am working with.
The fiinal cover will be black plastic, formed to mimic the original vacuum motors.
It will be a plug-and-play setup:
Unbolt the vacuum motor and bolt the electric one in its place.
Plug the connector into the headlight wire cicuit.
Hook up the fused power wire to the soleniod.
Turn on the headlights and watch the covers open.
Up/down stop adjustments are on top and easily accessable - just a screwdriver needed.
I am currently constructing the prototype.
Using a basic 12vdc electric motor to test the controller.
Getting the frame and pieces plasma cut.
Finding someone to make the plastic "can".
Again, sorry for the long dealy. Still trying!
"If just anybody could make this, everyone would"
Mike
