68 Mercury Cougar standard edition with a 418 cid stroker motor that has less than 2500 miles on it. The exterior is mostly straight with some small dings and rivet holes from where the vinyl top was removed by the PO and a 3" tear in the sheet metal by the back passenger side wheel well. The car runs great and I would not hesitate to drive it anywhere!!
The motor is a 351W block,
Eagle 14126 competition rotating assembly,
forged H-beam rods, SRP pistons,
Canton oil pan,
Camshaft innovations SFT cam,
Canfield 195 heads,
Victor Jr. intake,
1000 CFM drag race demon carb,
MSD billet dist.
MSD ignition system,
Hooker headers,
Aluminum radiator,
C4 with a Billet 4000 stall converter,
9" rear end with 3:55 gears & detroit locker.
Yukon 35 spline axles.
Includes a set of 28x10.50 slicks
I was setting up the car to run in the upper 10's. It dyno'd at 400+HP at the wheels.
if you want to come by and check it out reply to this ad. I'm located in San Diego Ca. $7000.00 obo Email me at [email protected] if you have questions.
Canton oil pan,
Canfield 195 heads,
Victor Jr. intake,
MSD billet dist.
Hooker headers,
Aluminum radiator,
