1 - 10 of 10 Posts
I have a 1968 Cougar with an automatic transmission and want to convert it to a manual transmission. If I purchase a donor 1968 cougar with a manual transmission, is it pretty much a straight forward matter of just removing the parts from my 1968 auto and replacing them from the donor car parts? Thanks. Jim
Hi Jim,
yes you could do it this way. The conversion is pretty straight forward.
In fact you dont really need a donor car for this. All parts you need can be bought and fit to your car.
I have done a 5-speed T5 conversion myself and I just bought the parts I need and it was almost plug and play!
Greetings from Bavaria!
Timon
I just noticed on ebay from Mustang Steve Performance (mustangsteve66), there is a complete pedal replacement assembly including power booster, set up with cable operator for the clutch for $740.
Hi Jim,
Timon
Can you identify the parts and sources where you purchased the parts? We have a 1970 XR7 with the 351 Cleveland and we want to make the same switch from auto to manual,
Alex in California
Hi Jim,
Timon
Alex in California
I've kicked around the idea of doing that but I'd rather just go with the original type of 4 speed on the floor. That way it will look period correct.
The other issue is that many of the modern cars with T5s are lighter and have a shorter wheel base. You might have to build the T5 up so it'll live longer and not just do shock replacement. That can get $$$.
All these V8 engines from the humble 289/302 and up have tons of low end torque and you can put practically any final gear ratio in the rear end that you want from 3:1 to 4.11:1. Sure a 5th gear is nice but unnecessary.
Consider that the stock C4 tranny can be locked into 2nd gear and driven that way in bad weather from 0 to about 55 mph.
That's 1 gear, not even 3 gears. I wouldn't want to try that on my Suzuki Crossover!!
My 68 cougar has a humble open 8" diff with 3:1 gears and a C4 with a slightly built up 302. It'll smoke the tires easy and they chirp when you floor it and go from first to second up to about 20mph.
Does anyone make a kit or parts list for that?
1 - 10 of 10 Posts
