I would like to raise the rear of my 67 about an inch. Has anyone removed the factory lowering blocks and if so, what was the effect on the ride and handling?
Hi,
If those blocks are like on the 69/70's, they are wedges and should not be removed unless the pinion angle is corrected some other way.
Robert
70 Cougar 351C 4 barrel with 4 wheel disks custom interior getting new paint mild cam AOD trans
I think that you are removing the pinion angle correctors and that will cause first vibration next driveline damage
