One of the things that I have noticed since I have built the Cougar, is that the engine started to tilt a little toward the passenger side, especially in the last year. From the very start I noticed that under heavy load, the engine did torque over pretty hard. I didn't think this was odd, since I was using stock 4th gen Camaro engine mounts. You can see in my very first drag strip pass how the engine tilts over:
So given that the mounts were rubber and that I made my own mounts, I thought one of two things was happening.
1. The mounts that I built have bent slightly.
2. The rubber inserts in the stock mounts have taken a set.
Once I was at John's house, we put the car on the lift just to look things over. It's always good to do an inspection and make sure everything was OK. The last thing I expected to find was this....driver's side:
Passanger side:
It appears that the two halves of the mounts are just stamped together and the lips that hold the two halves together have broken.
We called a bunch of local parts stores, but nobody had them in stock, and I had to be back on the road on New Years day. We proceeded to drill out the holes and bolt the two halves back together using 4 3/8" bolts on each side.
Unfortunately, the rubber inserts have deformed over time, so the engine was still tilting to the passenger side just a little, but it is much better than before.
Eventually I will either replace the mounts with stock ones, or get poly inserts (I really don't want to do that), or get the new Holley mounts that are reinforced and have poly inserts.
At least I know now that the mounts that I built are in good working order!
I am up over 700 subscribers on my YouTube channel! I really appreciate everyone's support, and please consider subscribing, if you have not done so already.
Andrew
