1 - 1 of 1 Posts
I have for sale a set of 8 17+cc dished pistons with 2 reliefs. They come with 8 pistons, spiro locks, wrist pins, and lower oil rings. They have less than 20 miles on them. They are great for superchargers, turbos, or nitrous applications. I was going to use them on a super charger application for a 347, but the customer wanted to go NA.
PM me if insterested or want additional information. Thanks for looking.
SCA-1-94180BE is the kit they are from. Go to SummitRacing and search.
THIS IS JUST FOR INFORMATIONAL REFERENCE ONLY. THE PARTS LISTED ABOVE ARE THE ONLY PARTS FOR SALE.
Actual Engine CID:347
Bore (in):4.030 in.
Bore (mm):102.362mm
Engine Stroke (in):3.400 in.
Balanced:Yes
Pistons Included:Yes
Piston Rings Included:Yes
Piston and Ring Oversize (in):0.030 in.
Piston Material:Forged aluminum
Piston Style: Dish, with a D-shaped cup
Piston Head Volume (cc):+17.00cc
Wrist Pin Style:Floating
Piston Ring Facing Material:plasmamoly
Crankshaft Included:Yes
Crankshaft Material:Cast iron
Rear Main Seal Style:1-piece, 2-piece
Engine Balance:External, 28 oz. imbalance
Connecting Rods Included:Yes
Connecting Rod Material:Forged 4340 steel
Connecting Rod Beam Style:I-beam
Rod Bearings Included:Yes
Rod Bearing Undersize (in):Stock
Rod Bearing Undersize (mm):Stock
Main Bearings Included:Yes
Main Bearing Undersize (in):Stock
Main Bearing Undersize (mm):Stock
Cam Bearings Included:No
Gaskets Included:No
Oil Pump Included:No
Camshaft Included:No
Lifters Included:No
Timing Chain and Gears Included:No
Plastigage Included:No
Assembly Lubricant Included:No
Quantity:Sold as a kit.
Notes:Includes flexplate and harmonic balancer. Connecting rods include 3/8 in. ARP 8740 cap screw bolts.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
These Scat engine rotating assemblies are available with either a high-quality Scat forged 4340 crankshaft or Scat's Series 9000 cast crankshaft and I-beam or H-beam connecting rods, with 7/16 in. or 3/8 in. cap screw bolts. For maximum power and reliability, Scat adds rod and main bearings from King, Federal Mogul, or Clevite 77, depending upon the application, and pistons and piston rings made by such well-known manufacturers as SRP/JE, Ross, KB, Mahle, Diamond, and Probe. Kits with cast and standard forged pistons have standard rings; kits with premium forged pistons have file-fit rings.
1 - 1 of 1 Posts
