anyone installed an ididit steering column?
Results 1 to 5 of 5
Thread: anyone installed an ididit steering column?
  1. #1
    Join Date
    Feb 2005
    Location
    hershey pa
    Age
    49
    Posts
    71
    I was wondering if anyone has put an ididit tilt column into their cougars? Any tips or things to look out for?
  2. #2
    Join Date
    Jul 2007
    Location
    vernon hills IL
    Age
    42
    Posts
    2,493
    Re: anyone installed an ididit steering column?
    i have a flaming river in mine. just make sure you get the right length
    Justin
    1969 cougar , 347 efi resto mod project!
    1964 galaxie 352 fe -currently undergoing restification!!!
    1996 f150 ,351 supercab , 4" lifted, hot rodded,monster tow truck !
  3. #3
    Join Date
    Jul 2010
    Location
    Gray, TN
    Posts
    36
    What is correct length?
    1969 Cougar XR7 Convertible => Restomod
    Jim Meyer frt suspension, Total Control Products 4 link Rear Coil over, Total Control Products Subframe Kit,
    2005 GT disc rear brakes/ mustang steve brackets, Tremec 3550 5 spd w/ hyd clutch, warmed over 351W, MSD EFI, JBA 1655s headers,
    Eliminator scoop and spoilers.
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    i installed the new solid state sequentional rear signals , and a gm type ididit coloum, any tips on the wireing set up to adapt under the dash?
  6. #5
    Join Date
    May 2011
    Location
    Albuquerque NM
    Posts
    54
    Quote Originally Posted by wendys67 View Post
    Connecting a GM switch in a 1967-68 Cougar requires some additional wiring. It cannot be wired like a Mustang.
    You also must use the WCCC LED rear bulbs and updated indicator relay to avoid burning out the switch.
    For the emergency flashers to work correctly, an Emergency Signal Adapter is required to supply the correct
    signal to the emergency warning relays located in the dash (67) and the trunk (67-68).
    This signal (514), not available from a GM switch, is +12V when the emergency flasher button is out (OFF) and open when pushed in (ON).
    The 1967 adapter can be constructed using with three Bosch-style relays and two diodes.
    The 1968 adapter is more complicated because of the way the turn indicator light grounds are connected.
    Contact me for details.
    Vic Yarberry
    Cougars Unlimited LLC
    Hidden Content
    '67 Cougar 289 2x4V 4-speed
    '68 Cougar XR7 390 4-speed
    '70 Cougar 351C-4V 4-speed Convertible
Thread Information
Users Browsing this Thread
    Similar Threads
    1. just installed the borgeson steering conversion in my 67 cougar
      By 68DUSTIN in forum Cougar Community Discussion
      Last Post: January 10th, 2014, 12:34 PM
    2. Just installed Borgeson integral Power-steering!
      By Ankou in forum High Performance
      Last Post: April 13th, 2012, 02:17 PM
    3. Ididit steering column wiring issue !
      By mikewoodson88 in forum Classic Cougar Tech
      Last Post: August 31st, 2011, 10:16 AM
    4. 1969 steering column and steering wheel
      By Gabriel_xr-7 in forum 69-70 Parts for Sale
      Last Post: November 15th, 2010, 02:45 PM
    5. Gap between Steering Column and steering box
      By oldschool in forum Classic Cougar Tech
      Last Post: September 12th, 2008, 06:27 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
